Hi guys. I am new here. I am looking for a solution. I have adler 069. When I use two different colours of threads, the bottom thread is seen on the top stitch. After I searched on the internet, I noticed that the problem causes because of the balance of feeding system. So is there anyone who can help me to adjust the presser foot and upper foot ?
Thank you
By Tom Mann
#5929
Yes it does look like the top thread may be to tight , I would double check the way the machine is threaded first then if you can't get it loose enough on the top tension start tightening the bottom thread tension
