Hi everyone!
I am new to this forum, and I'm really excited to join this community and share my passion for furniture design and engineering with fellow craftsmen.
For my first post, I wanted to share a recent project where I worked as a CAD designer. As we all know, a proper Chesterfield chair requires absolute precision, especially when it comes to getting the frame geometry exactly right for the deep buttoning and rolled arms.
**The Design Process**
My task was to design and develop the entire frame structure using SolidWorks. I had to calculate all the angles, dimensions, and layout details digitally to ensure that the factory team could assemble it without any issues.
The physical frame was built using a combination of pine timber and 15mm thick plywood, based exactly on my 3D model blueprints. The factory team then handled the workshop assembly, foam mapping, and the final upholstery work.
Below, you can see my frame design/assembly photos and how the final factory chair turned out.
*Caption: The frame construction made of pine timber and 15mm plywood, built from my SolidWorks blueprints.*
*Caption: The finished Chesterfield chair upholstered by the factory.*
I would love to hear your feedback from both a design and upholstery perspective. If anyone is interested in how to approach Chesterfield framing in SolidWorks, let's discuss!
Also, please let me know if you like this format of sharing the design and development side of furniture making. Should I keep posting more breakdowns of my CAD projects here in the future? Your feedback will help me decide!
Thanks for looking,
Dmitry_CAD
#22761
Here is the general layout with the overall dimensions of the Chesterfield chair.
As you can see, the total width is 1115 mm, depth is 950 mm, and the total height is 785 mm. The seat width is 600 mm, and the seat depth is 650 mm.
This gives a clear picture of the chair's proportions. I am currently preparing the detailed step-by-step frame assembly drawings and blueprints. I will post them here very soon!
#22762
Here is the first part of the assembly drawings for the Chesterfield chair frame.
I noticed that after compression and converting to JPG format, some of the finer details, letter callouts, and dimensions might look a bit blurry or hard to read. Don't worry!
Please use these images as a step-by-step visual guide for now. There is still a continuation of the frame assembly drawings coming up next. Once I post the second part of the frame drawings, I will upload a high-resolution PDF file for download. The PDF will be fully vector, so every single line and dimension will be crystal clear.
Stay tuned for part two!
LLeeT liked this
#22766
Thank you so much! That is a huge compliment. I spent a lot of time in SolidWorks trying to make these blueprints as clear, clean, and professional as possible, just like those classic woodworking plans.
As I mentioned, the vector PDF will be ready for download soon so you can have the crisp, full-scale drawings.
#22767
Part 2: Chesterfield Chair Frame Assembly Preview
Hi everyone, here is the second part of the preview, focusing on the step-by-step frame assembly and detailed nodes.
In my next reply right below, I will attach the full PDF file containing all of these detailed drawings for you to download. Stay tuned!
#22768
Here is the Full Frame Assembly PDF!
As promised, in this post I have attached the complete PDF file with all the detailed frame assembly drawings.
In my next reply below, I will also share the templates needed to manufacture this frame (the ones marked on the drawings). Enjoy and feel free to download!
(3.41 MiB) Downloaded 54 times
#22769
In this post, I am enclosing a preview image and the actual PDF file containing the template blueprints.
(1011.68 KiB) Downloaded 57 times
These are detailed pattern templates with all the specified dimensions required for manufacturing. The PDF is fully vector and in high resolution, so you can easily print them to cut out the frame parts accurately.
I would also like to mention that I am from Ukraine. I am currently translating all my Chesterfield chair blueprints from Ukrainian to English. Since I am just starting to learn English, I apologize if any technical terms or phrases are not completely accurate.
In my next post, I will share the detailed drawings for the foam parts of the chair. Stay tuned!
#22774
As promised, I am posting the next part of the chair drawings, and this time it is the process of covering the chair frame with foam. I am sharing a preview of the drawings and attaching a PDF file with these drawings.
(3.7 MiB) Downloaded 22 times
If anything is unclear in the drawings for this chair, feel free to contact me either here on the forum or, preferably, by email: [email protected].
By the way, I am currently looking for a permanent remote position in the design and development of upholstered furniture. If you are involved in the production of upholstered furniture, or upholstered furniture for yachts and cars, and you need a specialist in frame design, selecting filling materials, foam, or upholstery fabrics, I am ready to help you with this.
Here is my contact email: [email protected]
And also my Instagram: https://www.instagram.com/furniture.makers.diary/
