Greetings,
I have another marine vinyl project on my hands (got a new-er boat that needs some vinyl repair). It appears that the boat manufacturer used the wrong type of thread for exterior use. All the sun exposed areas have the thread disintegrating and the seams are opening up. The vinyl itself is intact, it is just the thread that is of issue. Here is a glimpse of the issue, where the seams are coming apart. Currently there is some tape holding the seams from separating further . . .
Just wondering what the collective wisdom would be on fixing this situation. I assume that all of the thread needs to be replaced with a UV resistant thread ( Tenara ), but just not sure if the existing vinyl panels can be re-used or if I should make all new panels.
BTW - there are a lot of French Seams in the stitching . . . little/no top stitching.
Thanks for any input/ideas on this
#13929
I see this all the time on boats. You dont need to use tenara. I would use a good quality bonded polyester made by either Coats or Amann.
You'll need to carefully remove the cover and restitch what you can reasonably access. As long as the vinyl inst torn you'll probable get a few more years out of the vinyl. If the vinyl is starting to rip then its time for new vinyl as well.
MalcolmM liked this
#13968
If you are only trying the repair the open seam as opposed to replacing the thread along the whole seam, and the vinyl is still soft and flexible you can hand sew it using the existing machine hole without the need to disassemble the assembly. Just depends on what your goal is.
I repair open seams all the time by hand, and as long as the material is flexible it looks like the original machine stitch.
