By Mikesimpson
#10095
I use the edge guides. I'm still getting the hang of keeping everything nice and straight. But it was a cheep investment and it seems to make it a little easier .
I use them. Use to use just my regular foot as a guide, like stated before. Cheap investment and I find makes the product a lot better. Tight corners can be trouble some. For those I just eyeball the needle and seam to try and stay even. Most times I don’t have to switch from left to right, as you can just turn the material in the machine. Most of the time.
Rug Dr. liked this
Haha yeah. All those feet can be helpful but Im lazy and dont like changing feet all the time. So I just got used to normal flat feet for everything except on welt.
Same here. I use standard foot for sewing and I made set of feet myself similar to what Cechaflo on YouTube often shows. Basically, big foot without one side and small foot with cut along hole line so I see needle.
I use that "custom" foot when I need to do slow work with exact needle positioning (like making holes for steering wheel cover)
I have all other types of foot but those guides can be 1/16-1/32 off depending how you look at it. Going by edge of standard foot is easier IMO and especially on tight curves I just draw a line with erasable pencil/pen where stitches should go.
#10162
I bought a couple of the guides but rarely use them, normally I have the regular foot on for everything but zippers. The hand eye coordination is good practice for long straight stitches.
