I am looking at this foam for seat repair. How is your experience with this foam? I am looking at this foam for Big Rig seat repair.
Never used it. Looks expensive to use for a seat repair. Any reason your considering this foam over regular foam?
@John,
I thought it would be cheaper than regular foam. I seen it in a supply catalouge but there was no prices maybe that why :wink:
#1295
It’s great for cutting and slicing, I’ve had problems with chunks falling out trying to curve it. Maybe my tecnique.
@Revv Up,
No I don't think it would be unusual for it to come out in chunks it is made from little chunks I can see that being a really big problem.
By LeatherJohnny
#1783
I have purchased this type of foam here in Spain at shops similar to Home Depot, and price for a full sheet of 50" x 80" x 1" was like $17. There were several densities and thicknesses available at the insulation section.
This rebond foam works very good, in some ocasions better than regular foam, as I don't have a supplier close to me that carries firm foam. Perhaps insulation rebond foam is different than the one you are talking about that seems to be more expensive?
@LeatherJohnny <
Did they call it Rebond foam at the supply chain? I have been through our Home Depot and they dont even carry rolls of carpet underlay like they had before.
By LeatherJohnny
#1792
BigRig wrote: Wed Jul 04, 2018 1:22 am @LeatherJohnny <
It was when I read this thread when I discovered that the name of this foam was rebond foam, and it seems that this foam is used for acoustic isolation. The foam is like that:
We have this type of foam in the building material and home improvement shops in Spain, so I'm sure that you will be able to find it easily in the USA. It works really well for upholstery, so I guess that here the upholstery equipment shops will carry it, but I don't have these shops near me... :disappointed: :wink:
By LeatherJohnny
#1793
I have just taken a picture of some "rebond" foams used as noise insulation material of different thicknesses and densities that I have purchased over the years:
It looks like it could have many uses for sure @LeatherJohnny
By LeatherJohnny
#1803
Yes, lots of possible uses! Some time ago I read here
http://www.thehogring.com/2015/02/23/10 ... ext-level/
a trimmer saying:
Another way I find ideas is by walking through the isles of my local hardware store and scanning all the shelves for things I can use in my own work. I can’t believe some of the things I’ve found that aren’t meant for trimmers, but come in really handy on the job. So keep an eye out!
And boy, he is correct! :wink:
#1807
@LeatherJohnny
Unfortunately The Hogring is not for us mere hobbiests to use, that forum is closed to the public.
By kl4bidn
#1808
I could see where rebond foam would be hard to sculpt as it is a recycled material of different densities of foam glued together. In the states they ship foam rolled up with the air sucked out of it. Don't use foam from JoAnn Fabric because it won't last. I use ultra foam from Albany Foam Supply. Their catalog is in .PDF format online. Albright's sent me some foam samples I just wish they had some code on them so I knew what I was looking at. Still lots to learn about foam.
I have Albrights High Density Blue Foam it is really good, trust that for sure. The rebond foam would be good for a seat center if you wanted to give a little extra density for a heavier operator. It will just spit and shred no way sculpting will be easy.
By LeatherJohnny
#1819
Revv Up wrote: Thu Jul 05, 2018 2:05 pm @LeatherJohnny
Yes, if I could read what I have indicated is because it seems that it was released before the forum was closed to the general public... thank goodness that some information is still available, as that one, and also, thank you very much to John for founding dis forum open to beginners like us! :wink:
By LeatherJohnny
#1820
BigRig wrote: Fri Jul 06, 2018 5:39 am The rebond foam would be good for a seat center if you wanted to give a little extra density for a heavier operator. It will just spit and shred no way sculpting will be easy.
Perhaps the rebond foam available in Europe is different, as I have always been able to sculpt it without problems with a knife or angle grinder with sanding discs, with all the different parts of it in their place? :confused:
@LeatherJohnny Your welcome! I'm really happy that you all are a part of it and are enjoying it so much!
LeatherJohnny liked this
