By ValerieJean
#22783
The seatback pocket on the bucket seat I'm recovering in vinyl has a wimpy hem that will probably stretch and droop over time. I have an example of a stiff pocket hem in my F-350 that I'm trying to mimic without taking those seats apart. It seems to be plastic flat stock that slides in the hem as the hem is stretched during use. It gives enough to not poke through the hem at the ends but is stiff enough to keep a nice firm shape over 20+ years of use. I've tried a few things, such as flexible cutting board (too soft) to sail battens (too hard). Elastic will fail after a few years and can't be replaced. I tried sewing grosgrain in the hem so it would not stretch, but it seems the hem will still roll down with use. Any suggestions? Thanks.
By Dmitry_CAD
#22784
Since a flexible cutting board is too soft and sail battens are too stiff (they distort the shape), you need a material with good "shape memory" that flexes but doesn't kink or snap. Here are the best options:
--- A strip cut from a plastic jug / gallon container (Free & Effective). Look for a heavy-duty plastic jug (like an empty motor oil, antifreeze, or laundry detergent container). Check the bottom for the HDPE or PE-HD recycling symbol. Cut a strip from the flattest side of the jug. It has the perfect thickness, won't crack in winter temperatures, and costs absolutely nothing. Pro-tip: If the plastic has a slight natural curve from the jug, orient it so it curves inward toward the seatback. This will pull the pocket even tighter against the seat.
--- ABS or HDPE plastic sheeting (1.0–1.5 mm thick). This is the closest thing to the factory OEM solution if you want to buy new material. You can get small sheets online or at car audio shops (where it’s used for custom speaker pods). It cuts easily with heavy-duty shears into strips of any width.
--- Plastic piping/welt (Keder or flat piping strip). Look for flat bag-making piping. It is made of PVC or polyethylene and is specifically engineered to hold the shape of bags and covers under constant load.
--- Hydraulic brake line tubing or heavy trimmer line (3-4 mm+). A great DIY option if you prefer a rounded hem. You just fish it through the hem. It provides excellent sag resistance while still allowing the pocket to stretch outward when used.
Why grosgrain didn't work (and how to beat the roll-down) Grosgrain ribbon prevents the hem from stretching horizontally, but it lacks structural rigidity. Without vertical stiffness, the vinyl will still roll downward under its own weight or when the pocket is pulled.To stop this from happening, do these three things:
-- Round off the plastic corners. Always cut the ends of your plastic strips into a smooth semi-circle and knock down the sharp edges with sandpaper. Otherwise, those sharp points will poke right through the vinyl in a couple of years.
-- Lock the insert in place. The plastic strip should fit snugly against the top and bottom of the hem pocket. Make sure to backstitch (tack) vertically at both ends of the hem so the plastic cannot slide left or right.
-- Pre-tension the hem (subtract 2-3%). This is the ultimate pro-tip: pattern the top edge of the pocket about 1.5 to 2 centimeters shorter than the actual mounting width on the seatback. When you stretch and secure the pocket during final assembly, the plastic insert will be under tension and physically won't be able to sag.
LLeeT liked this
By ValerieJean
#22785
What an abundance of great information! I'll start with cutting up a plastic jug.
I did wonder if the strip should be secured to prevent slipping left to right. The hem will not stretch that way, and I think that's what I want but not sure. The plastic in the F-350 hem does seem to slide a little because the hem stretches a bit. Won't securing it as well as patterning it a little small cause it to be too tight? One or two atlases is all that will go in there.
Thank you!
By Dmitry_CAD
#22786
You hit the nail on the head! You’re completely right about the mechanics. In your F-350, that pocket acts as a dynamic system. When you put something inside, the pocket pulls forward, which causes the sides to pull inward. If the plastic were rigidly locked to the vinyl at the ends, it would either kink or rip the stitches out.
Since you only need to fit one or two atlases, here is how you can balance tension and expansion perfectly with your plastic jug strip:
---- Don't lock the plastic; lock the channelInstead of sewing through the plastic, leave it free to slide, but limit its travel. Cut your plastic strip about 1.5 to 2 cm (around 3/4 inch) shorter than the total length of the hem channel. Round the edges, slide it in, and just sew a vertical tack at the very ends of the vinyl channel.
You might wonder if 2 cm is too much and if the edges will sag, or if the plastic shouldn't just bend with the pocket. Here is the exact physics of why that gap is necessary:
--- The Geometry Pitfall: When the pocket is empty, it sits flat—say, exactly 30 cm wide. When you slide a thick atlas in, the vinyl has to bow outward in an arc. To wrap around the book, the vinyl now needs more physical length—let's say 32 cm along the curve.
--- The Problem: The vinyl can stretch and pull forward, but the plastic strip cannot stretch in length. Furthermore, the distance between the two side seams on the rigid seatback remains exactly 30 cm.
--- The Result: If the plastic is cut to the exact 100% width, it will hit a hard wall at the side seams as the pocket expands. It won't have the "room" to form a smooth arc. Instead, it will either buckle sharply in the middle (creating an ugly kink) or aggressively push against the side seams, eventually ripping the threads.
--- Why it won't sag: Cutting the plastic 1.5–2 cm shorter gives it about 0.7–1 cm of breathing room on each side. When the atlas pushes the pocket out, the ends of the plastic strip can slide slightly inward toward the center of the shifting vinyl channel. The HDPE plastic acts like a flat leaf spring—it bends into a beautiful, smooth arc under the book's weight, and then snaps right back perfectly flat when you take the book out. The 1 cm of empty vinyl at the very edges is held crisp by the tight side-seams themselves, so it will never droop.
Adjusting the "Tightness" (The 2 Options)
Since you want to hold atlases, a super-tight flat pocket will indeed be too restrictive. You have two choices for the pattern:
---Option A (Flat & Simple): Cut the top hem just 0.5 cm (1/4 inch) shorter than the mounting width on the seatback. This tiny bit of pre-tension keeps the vinyl crisp, but because the HDPE plastic from a jug is slightly flexible, it will gently bow outward like a spring to accommodate the thickness of an atlas without sagging downward.
---Option B (The Bellows Pocket - Best for Books): Keep the top hem exactly 100% of the mounting width (no pre-tension). Instead, add an extra 2–3 cm of width to the bottom and sides of the pocket by incorporating small pleats or folds (bellows). When you put an atlas in, the bottom pleats expand outward, and the top hem acts like a rigid, straight hinged flap that opens up without stretching or distorting.
For a quick and clean result with a flat pocket, go with Option A and give the plastic strip that 1.5 cm of breathing room inside the hem!
